Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-03-2002, 11:35 PM
MaxSpeedSE MaxSpeedSE is offline
Send a message via AIM to MaxSpeedSE
Exclamation Eveyone Must Read This If Your Have A New Sentra
Hey guys, this qestion isent for me, i drive a maxima, but my friend just got a new Nissan sentra SE-R Vspec, the thing is bad ass i love sentras i use to have a 94 SE-R well anywayz, the question is we went to the track today and my boy has the 6 speed, and he just had so much trouple with traction, he would spin all the way threw 1st, then 2nd, he just could catch, he was still running good times at 15.5's but i hurd some of yall ran 15.1s can yall give him any tips ??
thanks
:bandit:
Old 04-06-2002, 05:55 AM
haze50 haze50 is offline
Send a message via ICQ to haze50 Send a message via Yahoo to haze50
I have raced mine a number of times. I also lost traction all the way through 2nd. The trick i used was to lay off the pedal a little, don't rev it too high off the line. The z-rated that come with the spec v tires aren't the greatest either a set of proxies would most likely help the problem, i will be getting a set as soon as possible.
Old 08-02-2002, 11:45 PM
oassaf oassaf is offline
try adjuting the limited slip
Old 08-03-2002, 06:56 AM
SER Speedalot SER Speedalot is offline
i've never raced mine at the track, but i had that same problem when i first got the spec v. and still do to an extent. i had a civic before this car, so to race i'd just rev at like 4 grand and drop the clutch. that was perfect, but on a spec you have to rev maybe at like 2 grand and slip the clutch. then once the car gets to about 30 or 35 let the clutch out completely, its kinda hard to explane, he'd really have to mess with it. but man does that car pull your head back when you don't spin the tires.
oassaf, how do you adjust the limited slip
Cam'ron
Old 08-03-2002, 03:29 PM
TeamJxticSpecV TeamJxticSpecV is offline
Send a message via AIM to TeamJxticSpecV
Racing
just wanted to say a bit about taking off.....I found out that if u keep your rpm's at 2000 and then when u go into gear u just floor it that it works really well. My friend can take off really well in my car but I am still learning...It just takes some practice to be an experienced racer, but your'll get it. The car is fast but you still need to know how to drive it..
PeaceH
John
Old 08-03-2002, 04:26 PM
I don't know how to adjust it but if u check the owner manual, or go to a dealer and ask them they should be able to help u out.
Old 08-04-2002, 07:41 PM
neurokinetik's Avatar
neurokinetik neurokinetik is offline
oassaf, adjusting the limited slip differential would accomplish nothing on this car, as it is already smoking both front tires...
What helps is drag radials, and taking all the crap out of your trunk (its a FWD, more weight in the rear hurts traction off the line due to weight transfer)
Learn to feather that clutch!
It is by will alone I set my mind in motion...
please read this I have a important question .thanks. graygoose Riviera 10 07-19-2006 02:50 PM
Im BAck Mofo's those of you that remember me read this i have gone through alot Redline_civic91 COMPLETELY off-topic 9 10-09-2004 11:41 AM
