Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-14-2005, 08:26 AM
85thunderbrat 85thunderbrat is offline
High idle in park
85 3.8 carb. When i put the bird in park the ilde is high unless i kick it down. Any suggestions?
85thunderbrat
Old 04-18-2005, 03:01 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: High idle in park
new plugs and wires, oil change (get synthetic this time)
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 04-22-2005, 06:15 AM
SteVB SteVB is offline
OR, you could address the root of the problem, THE THROTTLE KICKER (idle speed motor). but its always good to keep those MAINTENANCE items up to date too.
Old 04-28-2005, 01:41 PM
viper_e2000's Avatar
viper_e2000 viper_e2000 is offline
Yeah you should change the oil and change the spark plugs, mine used to do that alot. I changed the spark plugs and it's fine now.
Old 04-29-2005, 03:06 AM
Donald91tbird Donald91tbird is offline
Send a message via AIM to Donald91tbird Send a message via Yahoo to Donald91tbird
Re: Re: High idle in park
excuse the thread theft... but what exactly does synthetic oil do? Is it better for a '91 Fuelinjected 3.8. I read that it was good for highmileage engines. What are the pros and cons (if any)? Appreciate it.
Old 04-29-2005, 02:36 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Synthetic oil takes longer to breakdown and is able to withstand a lot more abuse.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 04-30-2005, 12:14 AM
alot of abuse like city stop and go! That is what I need to switch to.
Old 05-11-2005, 04:47 PM
likhootch likhootch is offline
high idle in park
I have an 1988 thinderbird witha 5.0l, i have replaced every part including egr, idle air bypass (numerous times), plugs, wires, oil, and egr spacer gaskets. All had no effect. The car has had the problem for 5 yrs. I am in the midst of converting the car from SEFI to Mass Air. I read an article that the cruise control amplifier in 80's fords caused all kinds of problem in unwanted acceleration without warning and there was a recall on the T-birds as well, but I never knew about it. Mine would actually go to 35mph from a full stop without me touching the gas. I also read that if you clean the throttle body, you remove a coating that can cause high idle. The new 65mm BBk throttle body I bought has a warning to this effect. Sorry I couldn't help you, but I am fighting the same problem.
Likhootch
Old 05-11-2005, 10:31 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Not sure if this will help you much, but when I used to own my '85 T-bird 5.0, on the side of the CFI unit, there was an adjustable screw for the choke that controlled idle speed. You might want to adjust that screw (not too much, it's been preset from the factory) and see what goes. It normally does that when the engine is cold to warm it up faster. As soon as the engine gets up to speed, the choke will let go and let the engine run on its own power.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-12-2005, 08:58 AM
Freak, Thanks, but I tried that also, still no help. I even checked the EEC-iV wires and replaced the computer, still nothing. One extremely frustrating problem, and like you said it usually only happens when the car is cold.
Likhootch
Old 08-11-2005, 05:04 PM
85Tbird 85Tbird is offline
Send a message via AIM to 85Tbird
Get the idle air control thing replaced. That's what I did and it idles just fine now. I'm not sure if the difference in engines matters for this problem or not though since I've got the 2.3L four. Just an idea.
