Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-14-2005, 07:43 AM
CanaMark CanaMark is offline
Fuel filter and o2 sensor
Where is the fuel filter located in a 1993 Jeep YJ, I6 5 speed, Sahara model?
My manual doesn't say nothing on its location.
O2 sensor connector is not connected. I used to see where it could connect, however now I think my fan blades got to the loose connection. The connector itself was mangled, so I couldnt just re-connect it. The o2 sensor itself is in good shape, along with the wiring to the o2 side connector. How do I figure out on the wiring harness side inside engine compartment, in the engine which wire goes to the o2 sensor. Again my manual on repairs for this rig doesn't say much. I have looked for frayed wires, I see some possible candidates. I have a volt-meter to check. But what am I looking for?
Old 04-17-2005, 03:25 PM
addihs214 addihs214 is offline
Send a message via AIM to addihs214
Re: Fuel filter and o2 sensor
The fuel filter is in the back just ahead of the rear axle. It is hidden by a metal plate that covers it. If you follow the fuel lines from the pump, forward, you will see the lines disappear behind a metal plate. That's where your fuel filter is.
Old 04-18-2005, 02:28 PM
Ok thanks, I never thought about following fuel lines. Makes sense.
Now I gotta find the damn o2 wire
