Old 04-14-2005, 12:43 AM
yahoolu yahoolu is offline
Post Lumina Instrument Panel Lighting Failure
I have a 1995 Chev Lumina sedan with daytime running lights(DRL). Last week the lighting for the instrument panel to illuminate the guages at night stopped working. Checked 15Afuse (#28), looks fine. Other lights on same fuse are working ( dome, glovebox, mirror map lights, etc.). Tore out dash cover and glass cover. Pulled instrument panel out as far as I could( restricted by gear shift indicator cable) and removed (twisted) all three bulb housings from back of circuit board to inspect. All filaments intact and no sign of burn out. I assume if one bulb had burned out, should still have some light from remaining two bulbs. This evening used headlamp switch to manually turn on lowbeams (normally done by DRL sensor), but panel lights still failed to illuminate.
Any assistance or reference to other threads would be appreciated.
Old 04-15-2005, 08:44 AM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
Re: Lumina Instrument Panel Lighting Failure
I'm not sure about if your switch is in the same place as mine, but it sounds like your parking light switch has gone to the metal graveyard. When you turn your lowbeams on, check to see if your tail lights are on too. I'd almost bet they aren't.
Old 04-18-2005, 09:09 PM
v6guy v6guy is offline
Check to make sure your tail lights are working, I believe they are on the same fuse. If this is the case check the under hood fuse box (drivers side). Pull it out and inspect the connectors, they may be corroded badly.
Old 04-24-2005, 07:36 PM
XTECH XTECH is offline
Re: Re: Lumina Instrument Panel Lighting Failure
I have the same problem on my 97 Lumina, go to this site for help.
www.lightsout.org/disable.html
You'll find some help here, I did.
