Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-14-2005, 12:53 AM
data1 data1 is offline
No Upshift Light
I have a 1997 Wrangler SE 5 speed w/146K that shows a trouble code # 37. I found on the web that for the manual trans. this code is for no upshift light. Is their a relay or fuse that controls this light. Code 37 is the only DTC I get when I do the code scan other than the begining # 12 and the end # 55.Thanks
Old 04-16-2005, 05:49 AM
CanaMark CanaMark is offline
Re: No Upshift Light
Is this the "Dumby gear shift light" that comes on to tell you to change gears? I got the same thing on my '93 YJ. At first it was comical, now I never see it on ever. I probably have same codes u get, but I got no check engine light.
Old 04-17-2005, 12:56 AM
Yes, it's the shift light on the dash. When I turn the key on it comes on for a few seconds then goes off but it dose'nt come on while I'm moving through the gears. My check engine light comes on with the code 37. I'm assuming the check engine would'nt come on if I could figure out why my upshift light was'nt working and fix it. I don't know how the light physically works, thought maybe their was a relay or fuse that might be the problem. Will probably have to get a wiring diagram and go from their. Thanks for the comment
Old 04-18-2005, 03:32 PM
Prolly has something to do with your RPM guage, and a sensor to see what gear its in. Yup diagrams, fun times, get some beers for the read!!
Old 04-20-2005, 06:52 PM
bdiamond69 bdiamond69 is offline
learn how to shift with out a light
Old 04-21-2005, 05:45 PM
JeeperRich JeeperRich is offline
I was happy when mine went away -- If I wanted the computer to tell me when to shift, I'd have bought an Automatic!
