motor & muffler mounts
On the '97 Blazer LS, 2WD, 4.3...
Two things the manual is a little vague on... How many engine mounts are there? Also..is there a way to tighten the muffler mounts? I tried the "strap" that goes around the back of the muffler, but it's tight already & the thing still rattles. As always-thanks! -Mike |
Re: motor & muffler mounts
The muffler is rattling?
Or is the cat rattling?
1995 Factory Blazer Service Manual for sale, PM if interested. |
I'm 99 % sure it's the muffler.
When it's rattling, I can make it stop by putting very slight upward pressure on it by hand. I figure that if it were loose catalyst in the coverter, it wouldn't quiet down quite that easily. -Mike |
Replace the muffler.
Is the rattle coming from inside the muffler or is the muffler vibrating against something? |
Re: Re: motor & muffler mounts
You need to check it out a little closer. If it is just rattling against something, you may be able to adjust or shim it and make the noise stop.
