Old 04-13-2005, 11:01 PM
silverstud_2 silverstud_2 is offline
1992 Ford Escort GT Stalling problems
Lately my car has been randomly stalling, i'm going to have it checked out this coming weekend but if you guys have ne ideas to help me out that would be much appreciated. Thnx.
Old 04-14-2005, 04:18 PM
n9rkd n9rkd is offline
Re: 1992 Ford Escort GT Stalling problems
I have the same issue though it has been far and few. I am suspecting a vacuum leak because it inly happens when I am slowing down to a stop sign or stop light from a relatively fast speed.
Old 04-14-2005, 07:31 PM
A. Souphound A. Souphound is offline
IAC valve may be sticking. Remove the IAC valve and spray it with Carb Cleaner. Put a drop of oil on the pindle shaft where it enters the housing.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 04-15-2005, 10:43 PM
Mmatto99 Mmatto99 is offline
Make sure the hose going from air cleaner to throttle body is completely on and sealed. Also disconnect battery for a few minutes and the it should be ok.
Old 04-18-2005, 01:29 PM
Hendrock Hendrock is offline
i have a 93 let me know if your car keeps shudering beecause if it is doing that you need to change the intake manifold gasket
Old 04-19-2005, 03:22 PM
95EscortGTX 95EscortGTX is offline
Check your intake hose for cracks, GT's are known for that, just bend it a bit to check if it has any leaks, electrical tape will fix it right up
