Old 04-13-2005, 09:57 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Smoking problem
I noticed this yesterday but didn't think anything of it since it happened only once...Until today. Also i noticed that for a long time now, my exhaust smells horrible. Doesn't smell normal. I replaced the cat a while back with a 'high-flow e-bay cat' which is basically a straight pipe lol. Anyway, when i hit boost my car starts to smoke pretty bad, and the weather here has been around 65 - 70F. I had a turbo blow up on me once and it smoked much, much worse than it is now...Do you think my turbo could be going bad or what?
EDIT >> I figured i'd post this in the same thread instead of making a new thread for it...A little bit ago when i went to start my car, my battery was dead. So i push-started it, runs fine until i flick on my headlights, then my stereo turns off. Same with the turn signals. If i stop and turn it off, won't start again. I think it's probably a bad alternator, but i wanna be sure before i shell out $130 for a new one. The battery is only 5 months old and it has to be drained if the alternator is bad and won't start. When i tried jump starting it with my dad's truck, it wouldn't come close to turning over. So i dunno if the battery is completely gone too or what.
Old 04-13-2005, 10:58 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Smoking problem
take your alternator in and have it fixed, it should only cost half the price of buying a new one.
95 Talon TSI AWD
97 Eclipse GST
Old 04-14-2005, 12:39 AM
joemathews's Avatar
joemathews joemathews is offline
Re: Smoking problem
What color smoke is it?
1996 Eagle Talon
Old 04-14-2005, 03:13 AM
Re: Smoking problem
like a bluish white color...and at idle like a dirty/brownish smoke...after a min or two at idle it was gone though
Old 04-14-2005, 07:48 AM
riff22 riff22 is offline
Re: Smoking problem
white could be a head gasket, or the turbo seals could be going bad mine smoked a litle bit because of the seals... to check your alternator take the negitave terimal off the battery while the car is running if the car dies then you need a new alternator, if it still runs then its fine, sounds like the alternator to me.
Old 04-14-2005, 08:51 AM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Smoking problem
rebuilding a alternator isnt that hard try it if you have a spare one thats liying around. Good old shop class I love high school all problems I can fix there for free, he he he. But if you dont feel like rebuilding it of fixing it you can send it to me and ill fix it for free.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 04-14-2005, 12:53 PM
pr0's Avatar
pr0 pr0 is offline
Re: Smoking problem
Blue could also be your valve seals if its not your turbo. Make sure your compression results are okay then you can eliminate the piston rings.
Pete (RS_T atx)
