Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 04-13-2005, 08:36 PM
artistic's Avatar
artistic artistic is offline
Oxyacetelyn torch
Does anyone have any experience with these? Right now I don't have a tool to cut through metal with and I was thinking of getting one. Does anyone know a good website that shows how to use them?
Old 04-13-2005, 09:57 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Oxyacetelyn torch
I have more experience than I could ever wish for. Dont know any websites but its more practice and natural skill than anything. Oxygen is set to 20psi, acetalyn is set to 5psi at the regulators. You turn them on at the torch body and turn the adjustment knob all the way down so its only letting out acetalyn when you strike, then adjust to a nutrual flame. You hold the torch at an angle to what your cutting, letting it set till its cherry red before pulling the lever and start cutting. When you first learn they tell you to hold the torch in your right hand and make a fist out of your left hand and rest your right hand on it to use as a guide. How far the tip should be from the surface varys depending on thickness and tip size but usually 1/8 - 1/4". I'm sure mike will toss in some more technical stuff and can answer more questions and stuff on it than me though.
Old 04-14-2005, 02:03 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
To make it easier to make nice straight cuts, I recommend getting a couple feet of 1"x1" solid square steel. Clamp it to whatever you're cutting and rest the side of the tip against it as you drag. Obviously you have to set it about a 1/4" away from the actual line you wish to cut.
Old 04-14-2005, 07:47 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I use a Henrob o/a torch. Thing works pretty awesome, however surprisingly I have never used the o/a for cutting. Only welding and heating.
TSC is spot on though.
-Mike
