Old 04-13-2005, 08:16 PM
angels7113 angels7113 is offline
Rubbing exhaust.
My new apexi exhaust is just a little to big for my car and touches all over the undercarriage and rattles and vibrates. Anyone know tricks or anything to stop the noise and is it bad for the exhaust to rub against the car?
Old 04-13-2005, 08:53 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Rubbing exhaust.
what is it rubbing aginst?? are the hangers attached correctly or at all?? rubber pieces on the hangers?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 04-13-2005, 09:08 PM
Scott82 Scott82 is offline
did you run it out the passanger side or drivers side? It's really tight if you run it out the drivers side, you have a little more clerance coming out the passanger side
Old 04-14-2005, 08:53 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
remove some of the heat sheilds...
Old 04-17-2005, 09:55 PM
fooshman3 fooshman3 is offline
Send a message via AIM to fooshman3
if you have any old rubber floor mats you can cut them up and put them in between the gap...its worked pretty well with mine for the past year
91 CRX Si
Chrome projector headlights, Clear corners, JDM style wing, GTS Tuner Short ram intake, 5Zigen Catback Exhaust, Random Techonology Test Pipe, Neuspeed Short Shifter, Neuspeed lowering springs, Tokico Gas Shocks, Bosch Spark Plugs, Bosch wires, 15" 04 Civic Si wheels, Sony F7700 CD player, Kenwood 6.5" speakers, JBL 12" Subs, SPL 1200W amp
Waiting to go on: DC sports cam gear
Need to buy: oil pan, maybe a mini me swap
Old 04-18-2005, 11:17 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: Re: Rubbing exhaust.
That's gotta smell nasty...
Mine used to do the same thing, I took it to a muffler shop and had them do a little cutting and welding to re-position it just slightly... worked pretty well. Doesn't rattle at all anymore.
