Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-13-2005, 09:15 PM
oxygen800r's Avatar
oxygen800r oxygen800r is offline
Question rough idle...bad alt?
i'm getting pissed dammit. first the broken handle now this. all within like 2 days.
i'm leaving class and my car idle dips to 100. i drive home and let it cool off. i tried to start it and nothing.
i took the battery to vatozone and they said it was bad.
i went ahead and grabbed a redtop and swapped them out.
it started nicely (assuming it was the full charge on the new battery)
then it dove down to 500 and stayed there, keeping a rough idle.
my first inclination was a boost leak. but would that make my battery die?
or was it just a weird coincidence?
silver 1998 mitsu eclipse gst
i'm now modless.
Old 04-13-2005, 10:13 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: rough idle...bad alt?
No it would not be a boost leak... you only really feel a boost leak when there is boost!
I would have your alternator checked because if it is going bad it won't be able to provide enough juice to charge the battery and keep all electrical running.. ie your spark...you should be able to disconnect the battery while the car is running and the alt should be able to keep it running...if it doesn't then there is a problem with the alt or wiring..bad connection, corroded wires.....
Just a thought......my
Have you done anything recently to the engine that might cause this?
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-14-2005, 08:20 AM
oxygen800r's Avatar
the last thing i did to my car was the fmic about a month ago.
the rough idle made me think of a boost leak but it was more of an afterthought.
i was going to try that old school alternator "test" but i have a powered sub and my alarm hardwired and i'm not too sure that those two alone won't suck the juice out of the battery.
i'll pull the alternator and run to vatozone to get it tested.
i'm now modless.
Old 04-14-2005, 05:11 PM
Just curious.. is Vatozone the hispanic version of Autozone? lol
Old 04-14-2005, 06:56 PM
oxygen800r's Avatar
autozone is vatozone because the one i go to is hood.
i had the alternator tested and it was perfect. i picked up a new set of ngk wires and i hope this is the problem.
if not, i guess i'll replace the coil.
other than that, i really have no idea.
i'm now modless.
Old 04-14-2005, 10:05 PM
oxygen800r's Avatar
not the wires.
tomorrow i'll put in new plugs. if not, i'll replace the coil.
other than that, i'm at a loss.
after i replaced the wires, i started her up. it idled normally until i put it in gear. then it dropped to ~200-400.
i'm now modless.
Old 04-15-2005, 10:56 AM
oxygen800r's Avatar
this is now only happening when i turn on the a/c.
i'm still hunting around the vfaqs and dsmtuners for any guidance.
if anyone here has any suggestions, please let me know.
EDIT:
this whole time i forgot to mention there is NO CEL.
i'm now modless.
Old 04-16-2005, 07:19 PM
oxygen800r's Avatar
so here's an update for anyone paying attention:
the throttle cable was getting "stuck" in various positions causing a weird idle.
i lubed it up and all is well again in dsm land.
but i may be in the market for a newer car soon.
in order to make room, my baby would have to go.
maybe.
i'm now modless.
