Old 04-13-2005, 07:16 PM
MSimpson MSimpson is offline
Many Problems.. Sounds... Gauges... Lights
I need some help badily.. Here it goes...
1. While riding on the intersate my Check Engine Soon Light Comes On *FLICKERS ON/OFF and then finally stays on.
2. Some in my exhuast is really loud... I am thinking my Cat converter.
3. Very rough idel... Engine whats to pull foward when breaking and make a VROOM... VROOM... sound.
4. While breaking my lights dim as they are about to go out.
5. Took it to get messages read and have a link error.
6. My RPM guage and my oil pressure gauge jump back and forth while breaking. You can't tell much while start to accelerate.
Here is the kicker... After cooling down.. No Check Engine Light or Exhaust Sound and Runs fine!! I need help!
Old 04-13-2005, 09:48 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Many Problems.. Sounds... Gauges... Lights
Go to autozone and get the codes scanned and come back with the exacy numbers they give you.
We need the number, don't allow the monkey at the counter to give you a dumbed down explantion of what is wrong.
Get the numbers and we can go from there.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-13-2005, 10:47 PM
I went to get it checked today and I had a link error.. guy said my computer might be going bad.
Earlier when I started my truck my ABS Brake Light Stayed On and my CD player wouldn't come on. Also I noticed my truck would not shift into gear and that my Air Conditioner wouldn't work. Sounds pretty bad. Then when I got home I turned it off and turned it back on and everything was fine.
Old 04-14-2005, 08:02 AM
After reading up alittle on the forums it sounds like my MAF sensor might need to be cleaned. But that still wouldn't account for my CD player not having power would it. Or my vehicle not wanting to shift. I will try cleaning the MAF today as well as getting a tune up. It's been a long time since I have had one.
Still don't understand why truck wouldn't shit and my ABS brake light was staying on.
Can anybody shed some light?
Old 04-14-2005, 09:44 AM
BlazerLT's Avatar
AF -Advisor
No, the CD player is unrelated.
Make sure you do a FULL tuneup, not just plugs and wires.
The ABS brake light will probably be from the VSS screwing up or the front ABS hub sensors needing cleaning.
Old 04-14-2005, 06:40 PM
I think I might have figured out some of my problem.. My ground wire to my battery was really loose. I reconnected it and now everything is running smoothly. But that wire being loose doesn't account for my Exhaust being so loud. I am going to get a full tune up and then see what happens from there.
Old 04-15-2005, 12:33 PM
BlazerLT's Avatar
AF -Advisor
Your exhaust could be loud because there is a leak.
But a FULL tuneup is probably a good thing.
