Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 04-13-2005, 06:24 PM
Charry Charry is offline
A/c getting ice
Bad news, my A/C its getting ice, I believe the high pressure line it’s clogged, or the condenser, I’m working on it, the liquid line it's in my hands, but today I left my a/c on for a while (30 min) and does't get ice but the comppresor does't stop, also the low press it's around 40-43 a high in 200-230, in normal iddle.
could be an electrical problem?any idea?
Old 04-14-2005, 06:34 AM
pies pies is offline
Re: A/c getting ice
what was the temperature when you took those pressure readings
Old 04-14-2005, 07:39 AM
Unhappy Re: Re: A/c getting ice
temperature inside or outside?
inside in the vent 40F blowing, outside around 75, when I driving in the freeway at 75mph it's when get ice, so a turn off the a/c switch and let the air flow for a while to defrost the unit.
Old 04-15-2005, 06:40 AM
Re: A/c getting ice
look in the engine compartment some where near where the a/c lines enter into the vehicle there should be a water drain. make sure that it is not plugged. it might look like a small round plastic tube sticking out of the fire wall.
Old 04-16-2005, 08:50 PM
good idea, I goin to check out tomorrow morning, but also a let the ac runing 20 min and the compresor does't stop, I increased the RPM to 3000 and does't stop, might be sensor, but witch one?
driving at 65 mph in the freeway the temp goes down to 18 F in any a/c vent.
Old 04-24-2005, 02:10 PM
Thumbs up Re: Re: Re: A/c getting ice
ok folks, my A/C finally is working the right way, someone jump a piece of wire in the low presure sensor or control switch, was replaced in the dealer, system recharged and tested. now my A/C goes on and off when is necesary.
