Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 04-13-2005, 06:03 PM
brettmojo brettmojo is offline
Send a message via AIM to brettmojo Send a message via Yahoo to brettmojo
Exclamation 2001 stratus r/t keyless remote programming
Hey I recently bought a few keyless remotes off an ebay auction that matched the one I have and I want to program them to my car. anyone know how I can do this without having to pay a dealer to do it? I've checked the manual and it says nothing. out.
Old 07-03-2009, 12:05 PM
bignig500 bignig500 is offline
Re: 2001 stratus r/t keyless remote programming
What up. I did some research and all you have to do is to take a riece of wire and put it in slot 1 and slot 4 of your computer diagonise port. It is located under the dash . basicaly lay on the seat and look under the dash. It should be to the right of the steering column. Its a black square box with slanted sides. Place one end of a small wire into slot 1 and the other end into slot 4. Then turn your the key on and after that it kind of gets tricky. I dont have the rest of the instructions but I will let you know the rest in a few days. Sorry
Old 07-03-2009, 07:23 PM
wafrederick wafrederick is offline
Banned
Does not work that way,has to be programed with the DRB III and this is the way with all Chrysler keyless remotes.The only option is to the dealer.
Old 07-03-2009, 08:17 PM
Well I just purchased a remote for my wifes 01 dodge stratus. And it came with the instructions on the 1 and 4 pin jumper to start the programing mode. Then I had to do a series of holding down lock and unlock.. followed by pressing the panic button. And thats how I programed hers. I must have got lucky.
Old 07-03-2009, 10:35 PM
Banned
That process is way too slow and the procedure with the DRB III takes less time.
Old 07-04-2009, 08:15 AM
That may be true. But buying a programmer or going to a dealership will will run you around 100 or so or you can use the wire that cost pennies.
Old 07-05-2009, 09:19 PM
Banned
It is less than a hundred dollars to get it programmed from the dealer.My father's 2006 Dodge truck was around $60.00 to program it.All Chysler keyless remotes are this way,programed with the DRB III.
Old 07-05-2009, 09:44 PM
I used the 1 and 4 pin trick and have not have any problems. It may have taken more time but it saved me $60.00 to get it programed. I am just trying to save the guy a few bucks. And not all chrysler keys have to be programed with the DBR you just have to know how to work around it if possible. In which I was successful.
