Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-13-2005, 05:57 PM
beatdown944 beatdown944 is offline
clutch pedal low
I just did the timing belt. turning on the car revealed a squealing belt. what I'm concerned with is my clutch pedal is pretty low and the fluid is low too, what type of fluid should I refill this with? the lack of a factory manual is obvious.
88 e300, needs work.
95 gsx, stock, sticky icky tires. SOLD!
Old 04-13-2005, 06:50 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: clutch pedal low
Any brake fluid will work. Be sure to bleed it properly. Air in the lines can certainly cause a low engagement point. Clutch fluid doesnt dissapear though, pull back the boot on the slave and look for fluid, and look on the insed of the firewall for fluid from the master.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-14-2005, 08:03 PM
Re: Re: clutch pedal low
I checked for leaks by the pedal assembly and on the firewall, everything is clean. I added some fluid and the engagement point is even lower. I should bleed the whole system. its weird because there are no leaks and the clutch was fine before I did the belts. some fluid knew there was some abusive driving about to take place and ran away.
it also took a few seconds for my oil pressure to rise to normal upon startup. I noticed the oil pan is dented in and I feel my (careful) use of it to hold up the engine while I changed belts may have dented it in further. any opinions? Not quite that bad but I want to drive it like I stole it.
Old 04-15-2005, 12:26 PM
AF - Advisor
Re: Re: Re: clutch pedal low
Thats real hard to say without being able to see it. Hopefully its alright. If I remember correctly, the 2g pickup design allows for a little more room for error than the 1g one. I would keep a close eye on oil pressure for a while. When I lost the motor to the dented pan, I didnt have a "real" oil pressure guage. If I did, I'm sure I would have caught something, if I was looking at it anyway.
Kevin Jewer
Old 04-15-2005, 02:00 PM
egads
I cant risk that. I will take it out(the pan)and try banging them out. thanks for the insight.
Old 04-19-2005, 12:30 AM
gstKillerRed07 gstKillerRed07 is offline
Banned
Send a message via AIM to gstKillerRed07
Yeah, Brake fluid works Great! got that tipp off this Thread thanks!
