Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-13-2005, 04:28 PM
seawja seawja is offline
EGR Valve
My 97 camry had the check engine light on a month ago. I found out that the problem is EGR circulation flow problem. From what I have read in the forum, many recommends that I clean the EGR valve first. I called more than 4 independent dealers, but all of them said they don't clean EGR. It is better for me to have them dignose the problem first.
I am so confused and wondering if anyone have any idea what I should do?
Thank you very much
Old 04-13-2005, 06:19 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: EGR Valve
Clean the EGR valve. They are just trying to get you in the door.
Take it off and clean it with solvent as best you can.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-14-2005, 12:33 PM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Re: EGR Valve
Can just as often be the tube supplying exhaust gas to the EGR valve that needs cleaning.
Been a long time since I've had to do that, but that's where I've seen blockages.
