Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 04-13-2005, 03:27 PM
swimshark swimshark is offline
Send a message via AIM to swimshark Send a message via MSN to swimshark
De-tuning Engine
Hey, since gas prices are going A-wall I was wanting to know if anyone has ever heard of de-tuning or changing the engine computer configurations so that it can go from using premium to using regular gas . Ive heard of people doing it to other engines and then will re-tune to engine to normal . If there isnt a way to de-tune it is it just okay to use regular and it wont mess up the engine?
Plus Ive heard that the J30 engines are de-tuned 300zx engines so supposedly you can either change a chip in the computer or change the configurations.
If anyone has any details please tell me gas prices are still rising here daily!
Old 04-14-2005, 12:10 AM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
Re: De-tuning Engine
shhh can you keep a secret?
ive been using premium once a month and the rest of the time regular unleaded...
and my car has yet to blow up
Old 04-14-2005, 09:45 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Originally Posted by swimshark
Hey, since gas prices are going ....
Cheaper gas does not necessarily mean more mpg --->Knock Sensor KS. When KS detect ping (often caused by low octane), it reduces ign timing until no ping. Retarded ignition means more gas will be burned. =Total costs up.
If detuning=cheaper gas:
- Retarded ign setting lets engine run with lower octane without blowing up. ...adjust...
More mpg ---> tune up your engine
More mpg ---> get your pedal behaviour in ctrl.
+++More mpg ---> You've got a wrong car, buy honda civic
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 04-14-2005, 08:11 PM
well i was wanting to know if anyone has ever heard of using a computer to alter the settings on the computer. ive heard of people redoing the idle speed and stuff like that. they didnt do it manually they changed setting on the computer
Old 04-16-2005, 11:03 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
What elevation are you at? Here in CO, you can use gas as low as 4 octane lower than the octane required for your car because of the elevation. So an S2000 or NSX can use 87 octane up here. I believe anyplace over 4000ft above sea level applies.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 04-19-2005, 02:27 PM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Change sparks plugs wiring tires shocks battery alter. check the converter to see if it clog also the oxygen sensor if it has stuff like that helps a lot
opcorn:
Old 05-15-2005, 10:42 PM
atl5p atl5p is offline
You can probably do this by adjusting the 'camshaft position sensor', and using a timing light. Drop the timing back to around 8-10' BTDC...that should let you use low octain gas.
Keep in mind:
This 'retarding' of your timing will give you less HP. That means that when you are used to accelerating at a certian rate before, you will now need to press the gas pedal further to achieve that same rate of acceleration. You know what that means, right? More gas is used. You will 'nil' out the effects of cheaper gas unless you really do drive slower (read: not gona happen).
Also, think of this. When you bought your car you knew you needed to use Premium, I'd assume. Back then let's say reg was $1.00 and prem was 20 cents more at $1.20. So, Premium USED to be 20% more expensive than regular.
Nowadays, regular gas is say $2.00. But Premium is still 20 cents higher at $2.20. Well, even though it's still 20 cents more, that's only 10% more due to the higher 'reg' price.
So if you put some logic into the deal, you'd quickly understand that there has never been a better time to use premium gas! It used to be 20% more expensive and now it's only 10% more expensive. RIGHT?!? And if you WERE willing to pay 20% more before, then certianly you should be willing to pay a mear 10% more nowadays?
TO EVERYONE: Gas was at it's highest in the late 80's at an inflation adjusted $3.50 gal. We are still some of the cheapest in the world, and the way premium seems to be set at 20 cents more than reg, no matter what the price of regular is, then we really need to spend our energies in more appropriate areas, rather than making our engines slugs!
Try instead a K&N filter, Flowmaster 50 series Delta Flow mufflers, and chrome tips to replace the collector box out back. You'll save more $$ that way in better gas milage AND have better performance.
Things arent always what they seem.
atl5p
Old 05-17-2005, 11:52 AM
Re: Re: De-tuning Engine
Originally Posted by atl5p
....You'll save more $$ that way in better gas milage AND have better performance.
atl5p
Yes and 10 points!
Here gas is at its cheapest - about 4.5$ per gallon, 95%taxes. Anybody there wants more of this socialism? Be happy and burn GAS.
