Old 04-13-2005, 03:04 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Curious about a sensor.
What would happen or what are the effects if the manifold differential pressure sensor (the sensor that is conected to the intake manifld) not working properly or not functioning properly. The wire that are connected to the sensor are all burned up thats why im asking.
Old 04-13-2005, 04:06 PM
Ogami Ogami is offline
When mine was bad, the RPM were all over the place. When I would be at a light, the rpm's would constantley go up and down once i replaced it went away. It was bitch trying to get the part becuase no one knew what it looked like, but I eventually got it.
1995 Eagle Talon Tsi Turbo AWD 5 speed
Old 04-13-2005, 04:37 PM
Re: Curious about a sensor.
[quote=Ogami]When mine was bad, the RPM were all over the place. When I would be at a light, the rpm's would constantley go up and down once i replaced it went away. It was bitch trying to get the part becuase no one knew what it looked like, but I eventually got it.[/QU
Do you think it makes the car slower though.
Old 04-13-2005, 04:48 PM
You never know what these senors might affect sometimes, but I didn't see any real drop in performance.
Old 04-13-2005, 05:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
Bad MDP sensor will not affect performance or the motors operation. It is simply a check for the ECU to see if the EGR valve is still working, much like the rear O2 sensor doesnt affect performance but is there to verify the cat works. Just more OBD2 BS. I have up on using that sensor years ago. In fact I have wired my wideband into that input so I can log it in DSMlink.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-13-2005, 05:37 PM
Re: Re: Curious about a sensor.
What do you think will boost up my turbo because it is slow right now and it was fast before.
Old 04-13-2005, 06:56 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
ok my rpms are shooting up and down to what sensor is it.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
