Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-13-2005, 01:31 PM
Lynnbug10 Lynnbug10 is offline
Question about tailgate on 99 Rodeo
The lock appears to be broken and I cannot open from the outside of the vehicle. Until I get the time/money to have this repaired--is there any way to open from the inside. The tailgate swings out and the top glass lifts up. I just got this vehicle and I am told by the dealership this could be a 300.00 job. Because it is so labor intensive. I just want to shop around on that pricing but I need to be able to unlock the tailgate for the time being. Anyone know what I can possibly do or not do?
Thanks
Lynnbug10
Old 04-13-2005, 06:35 PM
Ramblin Fever Ramblin Fever is offline
Is it possible it's just stuck rather than broken?
I've had mine get stuck from time to time WD-40 worked wonders.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 04-14-2005, 01:19 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Question about tailgate on 99 Rodeo
it takes 5 minutes to get that door open
crawl inside grab the net on the botom and pull the lower portion of the panel will pop out of place if arms are long enough reach inside feel around for linkage you will have to push or pull on the correct one to get the glass to open once gleass is open door should open finish removing the door panel look around to see whats wrong more than likely bent linkage or out of place
Old 11-26-2005, 06:32 PM
verica44 verica44 is offline
Re: Re: Question about tailgate on 99 Rodeo
Thank You, Thank You, Thank You.
I live on dirt roads and I have had a problem with my drivers door and now my tailgate, but this time the tailgate was closed and I couldn't figure out how to get it open, until now. Thank You!
Old 09-17-2011, 02:23 PM
CubsCubs CubsCubs is offline
I had a similar problem. I could not electronically or manually release my back window or door on my 2001 Isuzu Rodeo LSE. After several misfires, I came across this post. As the above poster said, "thank you thank you!"
Your post along with the following post which contains pictures allowed me to easily pop the glass open and troubleshoot why I couldn't get the window/door combo open:
http://forum.planetisuzoo.com/viewtopic.php?t=19672
