Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-13-2005, 12:51 PM
mustange kiler mustange kiler is offline
new piston rings?
hey my car is acting yp it ideals ruff and when i try to step on it makes this sputtering noise and fells like the car is not even going when i look at one of my spark plugs it hade oil all over the top of it and it was loose theres is no smoke comming out rs
Old 04-14-2005, 02:57 PM
pr0's Avatar
pr0 pr0 is offline
Re: new piston rings?
Well your valve cover gasket is probably leaking that's why there is oil on your plugs. and for the sputtering, I would say new plug wires. To find out if your piston rings are fried, go do a compression test. It should read anywhere between 180 and 225 if your rings are healthy.
Pete (RS_T atx)
