Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-13-2005, 12:46 PM
eroc13 eroc13 is offline
Angry 89 accord lxi surges and dies and hard to start afterward
ok to start with the car has newlugs,wires,cap, rotor,igniter,coil,main relay etc. the car normally does not have a consistent idle to start with. it varies from 500rpm to a little over 1000.and sometimes it will drop to zero rpm and die. when it does if i pull over it is hard to start.i hit the key over and over . sometimes it will fire a plug or 2 but wont start. after doing this many times it will start and run fine. but i noticed if i am driving and it dies, i pop the clutch and it will start.but this is intermittant. it doesnt lose idle all the tiime..please help me
Old 04-20-2005, 11:29 AM
chinzoo chinzoo is offline
Have you checked your PCV valve/filter/hose? If not - check it out.
Thanks
