Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 04-13-2005, 12:43 PM
coredog44 coredog44 is offline
Angry '85 jetta running VERY rough!!
One day I got in my 85 Jetta GLI and started it up and it ran like CRAP! It ran like it was missing horribly, but didn't really know. I changed plugs , wires, cap and router. No change. I ran a compression check and it is fairly close. When I took off my new plugs, there was wet fuel on them (a fair amount). Any thoughts? I bought the car real cheap, but don't want to give up yet. It seems like parts are so expensive!
Old 04-13-2005, 02:56 PM
boschmann boschmann is offline
Re: '85 jetta running VERY rough!!
Check the resistance across the coolant temp sensor pins (located in flange where upper radiator hose joins cylinder head). Resistance should be 2000-3000 Ohms cold & go to 200-300 Ohms at operating temp.
Old 04-23-2005, 11:08 AM
sc00byd0034 sc00byd0034 is offline
Send a message via AIM to sc00byd0034 Send a message via Yahoo to sc00byd0034
i was reading this and i have haveing a similar problem with my 89 jetta. if i dont get the correct resistance across there then what do i need tio do from there. is that a sensor that needs to be replaced or something
Old 04-23-2005, 01:29 PM
If the readings are incorrect, replace it.
