Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 04-13-2005, 09:48 AM
dalude_24 dalude_24 is offline
timing belt
I got a 94 prelude si h23. My car has 152,000 miles on it. Im not sure if the timing belt had been changed or not. Do you think i should change it anyways or what????I know it wont hurt to change it but is it worth doin it right away just to be safe.
thanks
dalude_24
Old 04-13-2005, 10:05 AM
sprayedlude93 sprayedlude93 is offline
Send a message via AIM to sprayedlude93
Re: timing belt
I would say you should. Also theres a recall on the 4th gen preludes Timing Tensioners. I would say replace that too...Maybe even your water pump and a full tune up if you havent already.
Old 04-13-2005, 10:13 AM
Mugan Mugan is offline
Re: timing belt
I would recommend replacing with a complet kit. I found my kit at www.honparts.net at a good price.
also at this time check your cam seals and water pump because you are looking at them when you change your belt.
Old 04-13-2005, 01:41 PM
lucentinjection's Avatar
lucentinjection lucentinjection is offline
Send a message via AIM to lucentinjection Send a message via MSN to lucentinjection
Re: timing belt
Yeah there is a recall on them...they dont keep the belt properly tensioned, so if you shift hard or go from like 1st or 2nd gear to a higher gear (skipshift) like into 5th, the belt gets slack in it and it can bend your valves...i had a car at work that this happened to...good idea to replace it
Old 12-10-2005, 02:47 AM
J-Roc J-Roc is offline
Re: timing belt
Are there any online manuals in pdf format I can use to guide me in replacing the timing belts on a 94 'Lude 2.3L DOHC?
Old 12-10-2005, 11:39 AM
Re: Re: timing belt
you can use the helm book i am sure. Also if you want you can use the H23 Tensionior. It will save you a lot of bull shit later. Well given that the auto h22 one losens
