Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-13-2005, 10:38 AM
gerboafalcon gerboafalcon is offline
Keyless Remote Programming
I have a 94 Mustang GT and just purchased a keyless remote...instructions say to locate the programming pins in the left rear quarter panel area...I see no "pins" in this area...some connectors in the left trunk area, but no programming pins...
Any help is appreciated...maybe a pic or a diagram of where these pins are...
Thanks....--Bob--
Old 05-23-2005, 12:36 PM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Re: Keyless Remote Programming
Thanks....--Bob--
Yes Bob, there should be a small grey connector behind the left rear trunk panel that is attached to the front of a black panel that may have another box in side it. All you have to do is jump the two pins in this connector and the doors should lock then unlock...press the lock button on the remote, doors should lock and unlock again, and the remote should work then. One other thing, make sure the remote you purchased is for that particular year model of your car. I recently purchased one and found out that it was for a newer car and would not work on my car. Finally bought the correct one and it works great now...
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
