Old 04-13-2005, 09:24 AM
V8Conversion V8Conversion is offline
Question CRX Steering Rack Removal?
I'm trying to remove an '89 CRX DX Steering Rack. How can I access the steering shaft u-joint pinch bolt?? It's hidden in a metal housing between the firewall and subframe.
Thanks,
Old 04-13-2005, 07:37 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: CRX Steering Rack Removal?
What I believe your talking about, you can access it from inside the car, theres a plastic piece that goes around the steering column, remove that and you should see the shaft and it's connected in there, you get it loose and it'll drop out. Might take alittle wiggling and different positions to get it out.
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-13-2005, 07:50 PM
Thank you very much for your help
Old 04-13-2005, 10:49 PM
travagliante's Avatar
travagliante travagliante is offline
yep FYI, make sure the steering wheel is straight. BTW it is a 10mm socket!
