Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 04-13-2005, 09:10 AM
Dayne Lancaster Dayne Lancaster is offline
Steering Lock
My 2003 Sonata steering wheel does not lock when turning the ignition switch to the lock position. Anybody ever have this or any ideas on what is the problem might be?
Thanks
Old 04-14-2005, 10:05 AM
chooper2 chooper2 is offline
Steering wheel lock
At times the lock pin in the column will become stuck.If you can use a spray lube with a tube supplied with the can ,try spraying into the column just below the steering wheel. Be careful not to spray too much into the column.Sometimes this will help the pin release. If this doesn.t work the steering whell will have to come off.
Good luck
