Old 04-13-2005, 05:01 AM
wrigley123 wrigley123 is offline
oil pan plug leak
I have a 2002 cavalier that seems to be leaking oil out from around the oil pan plug. I wanted to see if anyone else has experienced this mess. I change the oil in all my cars every 3000 miles religiously. When it comes time to crawl under the cavalier, I find a light mist of oil on the side of the oil pan and all over the bottom of the trans fluid pan. I have replaced the oil pan plug and gasket twice. Any thoughts? Thanks
Mike
Old 04-13-2005, 10:44 AM
5SpdCavy 5SpdCavy is offline
Re: oil pan plug leak
you could use some thread tape on the plug?
Old 04-15-2005, 05:49 PM
Nobody out there has experienced this problem?
Mike
Old 04-15-2005, 07:27 PM
Ryan066 Ryan066 is offline
never heard of any cavaliers with bad drain plugs... try putting two gaskets on the nut
or use some RTV sealant...
if not that dont work u must have got a crappy car from the manufator or something :///
Old 04-15-2005, 08:30 PM
Tookie Tookie is offline
From your attn to detail, I suggest you look at the drain plug proper and ensure it isn't crossthreaded. I'd also scrutinize the pan gasket looking for some place where the gasket may either be squeezed out; or missing a small section. there may be a loose nut or some bent edge on the pan itself.
Barring any of that I'd ascertain as to whether it is indeed oil, and not some other liquid like trans fluid.
Tookie
