Old 04-13-2005, 02:49 AM
rotatox rotatox is offline
Will lights damage models??
some of you may have seent the display cabinet i made a couple of weeks ago.. im looking at getting some downlights put in. DO you guys think the heat from the light will damage the models??? do you know if there are any low heat lights available?
CHeers
Frank
Old 04-13-2005, 03:06 AM
druid_99's Avatar
druid_99 druid_99 is offline
It all depends on the type of light used. I've seen models destroyed (I do mean destroyed) on a display shelf at some of the LHS here. All the models warped and deformed terribly beyond repair. I can't suggest any though as I'm not an expert in this, sorry. But one thing to bear in mind is that even with some heat the plastic and paint finish will be affected over time.
What is understood need not be discussed
Old 04-13-2005, 03:15 AM
Re: Will lights damage models??
thats what i was worried about too.....i was thinking about not putting lights in because of this reason. however i really like hte effect of lights on models instead of natural light.
Old 04-13-2005, 03:19 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Sunlight and fluorescent bulbs can fade things over time.
nightmaR3Z
Old 04-13-2005, 03:26 AM
druid_99's Avatar
Maybe someone with experience and expertise can answer your question that can be beneficial to us all. Sunlight can really dull the paint, and direct sunlight will even affect clear coats over time.
Old 04-13-2005, 07:24 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
use LEDs, jelly made a really cool display cabinet with about 20-30 LEDs in it, they give off bright light but they run cold (practically no heat) not enough heat to damage a model, im not sure about the light from them affecting paintwork though, my halogen 12v desk light gets really hot and melt plastic if its near it for a few mins (it melted my skyline bonnet/hood, it now has a big "dip" that needs putty to fill it.
so just be careful with what you chose.
Old 04-13-2005, 09:19 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
My cabinets have halogen lights with individually wired on/off switches and with a dimmer so I can use only the ones I want at any level I choose.
But I also do not leave them on for extended periods of time and have a thermometer inside on the top shelf to monitor the temperature.
I have to say the halogen light is very complimentary to models, but they can be very hot near the bulb. Like 2.2 said, be careful what you choose... - Mark
Old 04-13-2005, 10:04 PM
Fusionrr's Avatar
Fusionrr Fusionrr is offline
I just happen to work for a lighting company and I've just started monitoring the temperature of halogen downlights. The hottest part on the outside of the lamp reaches temps of 180 - 195 degrees celsius... regardless if their 12v or 240v.
If your models are about half a metre away it wouldn't be too bad but if their only 5cm away they'd melt... paint would come off... disaster
about 30cm away temp is down to 20-28 degrees celsius.
You can get LED replacement lamps for the downlights.. they do ran way cooler. even a fluoro tube runs at only 40 degrees celsius..
hope that helps...
oh.. you could always have indirect lighting if you want to use halogens..
Old 04-13-2005, 11:00 PM
led lights sound very good... the shelving is about 35cm spacing (if memory serves me right....i should go to a lighting store and see what they have available.....i was thinking fluoro tube, but they look to cheap to put in the cabinet. i dont know so many variables to think of!!
Old 04-14-2005, 12:58 AM
SoCalMark's Avatar
SoCalMark SoCalMark is offline
My case is white and the lights are aimed at the back, and the light reflects at the models. The lights are low watt lights like in a aquarium.
Mark
I like things that melt.
I dis-like things that don't melt.
Old 04-14-2005, 04:29 AM
Mark
that looks good, however a bit hard to do with my cabinet....i think im stuck with getting downlights. ill just try to minimise there use, which kinda defeats teh purpose
