Old 04-13-2005, 12:15 AM
stan_5150 stan_5150 is offline
passenger door "rub"
I've got a 2000 GT 4 door and I noticed the the passenger side doors "rub" when I close either one of them. I've looked at the mounting hardware and everything seems tight. It's more pronounced on the front passenger side then the rear door but it's bugging the heck out of me!!!!! Any help or suggestions would be greatly appreciated.
Old 04-13-2005, 06:41 PM
pistons6's Avatar
pistons6 pistons6 is offline
Re: passenger door
look at your doors to see if the body lines match if they dont them you might have to shim your door
Old 04-18-2005, 12:41 PM
Ok thanks.....stupid question #2
How do you shim the door? Do you have to remove it?
Old 04-18-2005, 04:53 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: passenger door
Has to be losen. Sims go in behind it.
Have you tried to "left" door from the bottom? That's a sign that there's something up.
Good luck
Old 04-18-2005, 10:51 PM
Re: passenger door "rub"
I've tried to lift up on the door and to see if there is any sign of loose hardware but so far no luck. Thanks for the help.
Old 04-19-2005, 12:11 PM
ericvrose ericvrose is offline
The adjusting points are accessed through the fender well when you take the inner fender well cover off.
Old 04-19-2005, 12:26 PM
OK I'll give that a look-see. Thanks.
(Any other suggestions would be great as well)
