Old 04-12-2005, 10:59 PM
Gunstar1's Avatar
Gunstar1 Gunstar1 is offline
Power drain on 79 T/A
I'm trying to help a friend find out what is draining the power from the battery when the car is sitting in the garage. The car runs, but when just sitting around, the battery gets drained and refuses to take a charge from a battery charger. The charger indicates that the battery is bad.
Things that have been checked or replaced:
Alternator: Tested good
Starter: Tested good, also replaced with a second starter.
Battery: Changed
All with the same results--> Dead battery
Even went through the fuse block and yanked all of the fuses, still resulting in a power drain on the battery.
The car started life as a Olds 403 / TH350, but now is a PMD 400 / TH400, so I'm guessing the problem is somewhere in the engine compartment because of the engine swap, not the interior of the car or the headlamp/taillamp/brake light system.
Although maybe a shorted switch somewhere? But I would think that removing the fuses would eliminate that from being a problem.
Could it be possible that something in the distributor may be bad even though the car will run?
Andy Hilbert
Gunstar Racing
1997 Pontiac Gran Prix GTP
1977 Pontiac Firebird
Old 04-13-2005, 12:09 AM
Tim81ta Tim81ta is offline
Send a message via ICQ to Tim81ta Send a message via AIM to Tim81ta Send a message via MSN to Tim81ta Send a message via Yahoo to Tim81ta
I would think a short somewhere along the line. Not sure of the setup used, you might have a solenoid that went bad, but I am not sure of the setup. If you have removed all of the fuzes I would look into something like that. Reason I say this, is I had a buddy witht the same problem, but different vehicle. Hope this helps, let us know how things go
Tim81TA
Old 04-14-2005, 12:54 PM
volkerc's Avatar
volkerc volkerc is offline
Re: Power drain on 79 T/A
Battery: Changed
check for a light in the glove box and trunk, staying on after those are closed....
Old 04-15-2005, 07:00 PM
Gunstar1's Avatar
Looks like this is going to become a challenge to find this bugger.
Thanks for the suggestions!
Andy Hilbert
Gunstar Racing
