Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 04-12-2005, 10:26 PM
motorman1 motorman1 is offline
Question stock LS burnout!!
can you and how easy is it to do a burnout in a
2004 LS v6?
also has anyone done a LS burnout before?
If it ant a Rotary it ant a motor!!
Old 04-13-2005, 06:38 AM
carpoof carpoof is offline
Send a message via AIM to carpoof Send a message via MSN to carpoof Send a message via Yahoo to carpoof
I would say you can do a burnout in almost any car. Well, I have a 2000 V8 with generic tires, it is quite annoying when you turn off the traction control because it will smoke the tires for about 5 or 6 car lengths from a stop. Now with a V6, I am sure you can get it to do something, but you may have to "Power Brake" a bit. The "Problem" is that the LS has a near perfect 50\50 weight distribution so there is more weight pushing on the back tires giving them more grip, plus the rear brakes are humongous which if you are power braking, it will reduce the wheel spin more. Good luck.
