92 buick
Okay now i Have a 92 buick leSabre and i am tring to put a new stereo in my car. i took some of the main dash off but cant seem to get the rest off
i could use some help so please help Last edited by Gassymatty; 04-13-2005 at 11:28 AM. |
To get to the radio:
Remove fake wood trim on both sides of steering wheel by gently prying it upward. Remove all air conditioning vent direction pieces. To remove, put a screwdriver under the bottom of the piece and gently pry up and toward you and it will pop out. Then spin it left or right and pull the top outward. Remove glove box, (don't forget the screw inside the hole where the air conditioning vent piece was.) Remove trim piece over the whole left side of the front of the dash, such as the instrument panel, by removing all screws holding it, including the ones inside the vent holes where you removed the vents. Now you have access to the radio. It has five screws I think. Three on the outside where you can easily access them, and two under the radio toward the back of the radio. All screws are torx and/or 7mm. Good luck. |
