Old 04-12-2005, 08:20 PM
SOOO Befuddled SOOO Befuddled is offline
Send a message via AIM to SOOO Befuddled
Intermittent starting/stalling
Okay, so I have had this 92 Blazer 4.3 since September 2004. It ran great for a month, like a dream. Before I describe the problem/s, I would like to say I do not have the vortec. The first problem I noticed was a shimmy at 60 mph, from reading the posted messages I found I should check the U joints but, since I cannot keep it running, this is hardly an issue at this point. I drove it for about an hour and stopped for a red light, it died when I started thru the intersection when the light turned green. It started right back up again and I drove it home. The next day I drove it about a mile away, stopped and waited at a light, same thing happened. Later that day I drove about a mile and was stopped in traffic and it died. No warning, it just died. It would not start so I had it towed to a mechanic I thought I could trust. He was 99.9 percent sure that it was the ignition control module, about $300 for that, parts and labor. I wish I had done that repair myself. Same problem the day after I picked the Blazer up, he changed out the same part. Took it home, next morning it would not start. All winter it would start when the temp got around the mid 30's but not anything below that. Changed out the ECM on advice of mechanic friend, same problem. Temp here finally in the 40's during the day so I drove it to work today, it started fine this morning. Different story this afternoon. Now what should I do,? I cannot afford to keep throwing money at what MIGHT be the problem. The original mechanic said he was 99.9 percent sure the third time I took it in that it was little box he called the spark control module. I took this to the local dealer and they called it the knock sensor and told me that it could not possibly cause the problems I am having. Please help, I need this vehicle and cannot afford any more bad advice.
Old 04-12-2005, 08:34 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Intermittent starting/stalling
change the distributor cap/rotor, sparkplugs&wires & coil wire. i'm pretty sure this tune up will cure the problems also check the coil for any cracks or excessive rust where it mounts to the bracket.
Old 04-12-2005, 08:35 PM
Maybe I should note that I was having a bit of a power problem, replaced plug wires that were in bad shape, replaced distributor cap and rotor before anything else.
Old 04-12-2005, 08:37 PM
Re: Re: Intermittent starting/stalling
Also Checked Coil, bought a new one, checked to make sure they tested the same, thank you for trying to help.
Old 04-12-2005, 09:11 PM
Re: Re: Re: Intermittent starting/stalling
Forgot to mention that mechanic wasn't getting any codes. Not only that, it kept erasing his stored codes.
Old 04-12-2005, 11:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
How about the plugs?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-12-2005, 11:20 PM
Sorry I did not mention. Tuned up late August, Champion plugs.
Old 04-13-2005, 12:56 AM
BlazerLT's Avatar
AF -Advisor
Have the fuel pressure checked.
Old 04-16-2005, 04:01 PM
Smile Re: Re: Intermittent starting/stalling
Will not start today, started yesterday. Checked fuel pressure. 12 psi. Just a tad low <~~ sarcasm. Changed filter, pressure reading 7. Guess I tackle the pump next, what fun... Will also check sending unit while I'm in there. Advice?
Old 04-16-2005, 07:27 PM
BlazerLT's Avatar
AF -Advisor
Do you have the TBI or CPI 4.3L?
Old 04-16-2005, 09:02 PM
TBI, thought I had mentioned that in my first post.
Old 04-16-2005, 11:31 PM
BlazerLT's Avatar
AF -Advisor
I believe 12psi is actually good for a TBI.
Old 04-17-2005, 12:20 AM
Okay, now pressure is next to nothing after changing fuel filter. Do you have any suggestions on what I should try next? Should I change out the pump? Some days the little bugger will start and some days it will not. I don't know where to go next so any suggestions would be greatly appreciated.
Old 04-17-2005, 12:26 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
sorry, but im lazy, your first post is to long, but my jist of it is your havein a fuel problem and you dont know if your pressure is right, go get a hayns (sp) manual for your truck, it will have all those kind of specks in it for you, and b4 i would go to the work of changing a fuel pump, i would make sure my ground was a good solid ground, all relays have good contact, and (i see youve already done both of these) fuel pressure regualtor and fuel filter
Edit: got board and read your post, the dealer would of corse tell you it cant be a problem, that way you say what is it? and they respond with o i dont know, we can put it on the machine for (here 72 usd) and tell you what 300 doller part we would like to install for you, or they will say other then that you can TRY and they will give you a list, especally if your machanicly inclined or female... and another note from doug, seince it doesnt want to run right when cold, how about throwing some dri gas into her, it is "throwing money at her" but only a couple of bucks, i suggest you go get some heet or peak dry gas and put it in the tank, a bottle for a tank should be plunty, if your real low, you need to put gas in b4 the dry gas, (its bad to have a bunch of that stuff in a small amount of gasolien) the fuel pump gets warm when working, specally on half a tank or lower, that causes condencation and vwala you have water in your gas tank causing you to run like shit
Old 04-17-2005, 02:33 AM
BlazerLT's Avatar
AF -Advisor
You will have to cycle the key to the on position (not started) for 3 seconds and back off for 10 seconds about ten times so the fuel pump can remove the air from the fuel system and regain the prime.
