Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-12-2005, 07:53 PM
DT22 DT22 is offline
Send a message via AIM to DT22
Question Factory Radio
I have 94 Regal. I just got the car. It has a aftermarket radio in it. I just got a factory radio. And i wanted to know where does the aentenna plug into? This is the first radio I got that the aentenna does not plug into the back of it. Hope someone can give me a hand. Thank`s J.J.
Old 04-13-2005, 10:20 AM
xoros xoros is offline
Re: Factory Radio
The actual radio reciever (where the antenna plugs into) is located directly behind and below the glove compartment. (look for a little silver colored box with heat sink fins on one end of it)
Where you actually turn on the radio and use the buttons, is just the radio control module...... it is not the actual radio.
Odds are if someone installed an aftermarket radio, the reciever may have been removed from behind the glovebox... or it might still be there - depends if they took it out or not.
Old 04-13-2005, 04:36 PM
Re: Re: Factory Radio
Thank you for answering quwestion. I just got done looking were you said and there`s no little silver colored box. And you can see this box with out taking glove box out correct? Thank`s J.J.
Old 04-14-2005, 08:14 AM
Re: Factory Radio
Yes, you can see it when loosen that lower panel and just look up behind the glovebox. It should be right there, you can't miss it... if you don't see anything they probably took it out.
I know I took mine out when I put in my aftermarket, I still have the old reciever - If you really want one I would be willing to send it to you free provided you just pay the shipping lol
To be honest, my aftermarket radio sounds ALOT better than the factory one ever could.
Old 04-14-2005, 04:22 PM
Re: Factory Radio
Thank`s again for your answer. And will look again. I will post again to let you know if there or not. Then if not I`ll get that one off you . For what you want.
Thank`s J.J.
Old 04-16-2005, 11:25 AM
Re: Factory Radio
I would like to get that reciever off of you. What would be the cost to get to me? How would I get in contact with you? I have messengers like aim,icq.
Or i can give you my email address. Let me know
so I can send money to you. Thank`s J.J.
Old 04-16-2005, 12:30 PM
Re: Factory Radio
Check your pm list. I pm'd you.
Old 04-17-2005, 01:22 PM
Re: Factory Radio
check your pm list.
