Old 04-12-2005, 06:48 PM
Johnny916 Johnny916 is offline
Help! I Was On My Way To School But My 2000 Silverado 5.3l Truck Won't Start??!!
Hi, I can't believe I'm missing school.
I tried to get into my truck and take it to school when the engine won't start. The battery seems fine though. It cranks ok but just doesn't start up. It's an Automatic trans.
I do notice the battery light comes on and stays on though but all the lights turn on and the engine cranks itself. So what should I do now? No one's here to jump me. I don't have a self starter battery pack.
Do you guys think it's the battery or what??
Old 04-12-2005, 07:02 PM
Hi, it's been about 15 minutes now! Here's what happened.
I just tried to start the truck again and it worked now! Started right up. But now I'm afrraid if I go somewhere will I be left stranded??!!
What could this problem be? I really can't afford to pay for an expensive mechanic so I'm going to try to fix it myself.
It's funny how one minute it will start right up and the next it just cranks but won't catch!
Old 04-12-2005, 07:57 PM
silveradoking silveradoking is offline
Re: Help! I Was On My Way To School But My 2000 Silverado 5.3l Truck Won't Start??!!
fuel, compression, spark plugs......change your plugs, wires.....fuel filter and see what happens....
Old 04-12-2005, 09:59 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Before you go spending money on stuff like that that you may not need, have your alternator tested. Those are nearly exact symptoms that my truck had when my alternator died. Always try to test anything and everything you can cuz when you go out and buy a bunch of stuff that you may not need to fix the vehicle you'll be kicking yourself in the butt.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 04-13-2005, 12:54 PM
mercurysniper mercurysniper is offline
Send a message via AIM to mercurysniper Send a message via Yahoo to mercurysniper
Before go changing all kinds of expensive parts, check your fuses to your fuel pump. I've had the same problem you explained and spent well over $200 to change the starter, jump the battery, all kinds of shit, and it turned out to be a burned out fuse. Now I know you are thinking, if its a burned out fuse why did my truck start, I have no idea but my truck did the same thing. It would not start at all, the engine would turn over but no combustion, but when I had a mechanic come and look he cranked it and it started right up. He then shut it down and tried again, and this time no start, just the engine turning over. He checked the continutity on the fuel system and found it was a 40amp fuse. Hope this helps.
Old 04-13-2005, 04:24 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
It could also be the passlock system screwing around , it happens alot on these trucks.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 04-26-2005, 01:28 AM
tallica_28's Avatar
tallica_28 tallica_28 is offline
just go to kragan or autozone they do free battery, starter and alternator tests.....Also check your battery cables...chances are you have side mount cables and come loose easily....my dad's 97 does it ever so often....its happened once to me and at a green light of all things.....
Old 04-26-2005, 08:33 AM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Hmmm. I'll agree with passkey or fuel pump. My '02 Tahoe lost 2 fuel pumps in three months, but once it was running, it would start fine after that for awhile. If it does it again, smack the bottom of the fuel tank with a rubber mallet. GM should equip the trucks with a mallet holder for just such an occasion.
