Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-12-2005, 05:33 PM
domesticdisturbans domesticdisturbans is offline
vrooommm possible?
i heard it was possible to run nitrous with a turbo kit is this true and what would be some preperations to do this ?
i am thinkng about it just wondering some things i would have to do to hook it up .
thanx
~shawn~
Old 04-12-2005, 05:40 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
I've only seen kits for imports with turbos. It mounts on the intercooler i believe.
Old 04-12-2005, 09:16 PM
mysatilac's Avatar
mysatilac mysatilac is offline
You can add a NOS to just about anything, although with a turbo kit your compression is already higher, your timing is retarded, So you risk detonation even more than normal, but if you want to try it before you buy it, here's a $40 kit before you go blow a couple hundred bucks
Granted this is only like a 20 shot but its still a little NOS into the intake... and this kit is pretty hidden and sneaky...No big bottle... and I can buy refills at the local flea market (whip-it cartriges, whip cream fillers...)
$40 kit
second kit, better view
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 04-13-2005, 01:10 PM
Re: vrooommm possible?
aight i was just wondering about the whole idea of it .
how far should i retard the timing for a turbo???
and what are soem good kits or peices for a kit
thanx
~shawn~
Old 04-13-2005, 01:30 PM
mysatilac's Avatar
I'm not a turbo guru, but these guys are... They should be able to help you out, especially turbosaturns
http://www.turbosaturns.net/
http://www.saturnmotorsports.com/
http://www.qksltwo.com/
Old 04-14-2005, 06:16 AM
emkay4597 emkay4597 is offline
something to check, a turbo and nitros (i've heard) can blow the head off without a wastegate...
Old 04-14-2005, 12:49 PM
mysatilac's Avatar
With any good turbo kit, you should get a blow-off valve, and wastegate...
Go to this forum and post here: forced induction
Old 04-14-2005, 05:50 PM
sweet thanx mysatalic
geez sounds like that would be brutal riping down the strip and bam through the hood head goesLMAo
thanx all
~shawn~
