Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 04-12-2005, 03:36 PM
kpic kpic is offline
Fuel pump relay..or??
Hi all, my GF has a 1994 J30 that is having intermittent starting problems. When it starts it runs great, but a few times (like now) it cranks-almost starts-and then nothing just keeps cranking.
I have checked for spark while cranking (ok) and fuel (not ok - no fuel just what was left in the line) as far as I can remember there is no noise from the tank area and has no other indications that the fuel pump itself was\is going out, I am pretty sure it is the fuel pump relay or something like that , anyone know where it is located on this car or if there is something else like a relay that could cause the non-starting? Thanks!
Old 04-12-2005, 08:42 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Fuel pump relay..or??
Originally Posted by kpic
Hi all, my GF has a 1994 J30 that is having intermittent starting problems. ....!
Check out the fuses first. The fuel line goes stiff as fuel pressure is up, check. Pump starts as key is turned, result is noise at minimum...
In maxima the relay is in the rear trunk wall under the panels.
log on www.autozone.com :chiltons online crap manual is available...
Other than fuel line:
- Ign key worn (=intermittent),
- ECU does not receive pwr up signal.
- ECU does not do its job for some reason: no injection or spark.
Injectors will click as the cam sensor is turned (mark position, take off, rotate) while pwr on.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 04-19-2005, 02:30 PM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Fuel filter clog fuel pump not good or fuse
opcorn:
