Old 04-12-2005, 03:14 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
oil leaking. Oil sending unit?
I went under my car to see is my oil pan is leaking, it looks like its coming from the oil sending unit. So do I neeed a new oil sending unit or is their a gasket or something?
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 04-12-2005, 03:37 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: oil leaking. Oil sending unit?
are you sure it's not coming from the front crank seal? that's what happened to me. i had a leak near the corner of the pan and replaced everything and it was still there. pulled off the timing belt cover and it was pouring out from behind the crankshaft timing belt pulley. i just replaced the front seal and i'm now puttin it back together.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2005, 03:40 PM
Humm I will have to look, what is invloved replacing that seal? How much did yours leak.
Old 04-12-2005, 09:02 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
dose it constantly leak?
when i would boost my car alittle and i got home it started dripping all over the oil sending unit, look up and it was just my dip stick poping out spraying oil all over the motor.... damn you 15 year oil dipsitck
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-12-2005, 09:05 PM
It only leaks when the car is running.
Old 04-13-2005, 12:55 AM
mine only leaked when the car was running too. replacing the front seal is one step farther than a timing belt job.
you take off all the necessary components to do a timing belt, take off the timing belt and then pull off the timing belt crankshaft pulley. to do this you'll need a puller. don't use the jaw type pullers though, you'll break the crank pulley. use the type that you have to use bolts for. you'll need 3 (i got 4 in case i broke one) 6" 6MM metric bolts with a 1.0 thread pitch. i got mine at mac's. they're kinda hard to find them that long. be sure to soak the crank pulley and shit down good with pb blaster the day before and spray it on about 10 minutes before you pull it off. pull off the crank pulley and there will be a seal inside of it. i just used a screwdriver to pull it out.
to put the new seal in i used a socket that had the same diamater of the metal part of the seal and tapped it into place lightly. you'll then need to put the crank pulley back on in the same manor. using a socket that's a little bigger than the inside diamater of the crank pulley and make sure they key stays lined up straight. put that all the way on and then basically do a timing belt job. i put on a new timing belt as long as i had everything off.
95 Talon TSI AWD
97 Eclipse GST
Old 04-13-2005, 01:08 AM
???? ???? is offline
Banned
How hard is it to replace the oil sending unit?
Old 04-13-2005, 10:15 AM
Its leaking form the oppisite side of the motor. More to middle right not the left.
Old 04-13-2005, 09:38 PM
97_3clipse's Avatar
im thinking turbo, check the feed and return lines...
Old 04-13-2005, 09:45 PM
he's got a gs. have you replaced the valve cover gasket lately?? they leak off the backside sometimes and it makes quite a mess down the backside of the engine.
95 Talon TSI AWD
97 Eclipse GST
Old 04-13-2005, 11:30 PM
Nope, but it is coming from down their. Their is no way it is coming for anywhere but around their.
