Old 04-12-2005, 02:54 PM
92civicCX 92civicCX is offline
Send a message via AIM to 92civicCX Send a message via Yahoo to 92civicCX
(HELP) wiring from d16a6 to d16z6 vtec
wasup guys. i need help on my wiring. i have an 88 civic dx std and im putting in a d16z6 SOHV VTEC complete motor out of a 93 civic ex. ive been browsing everywhere and cant really seem to find out how to do some wiring. i know how to do the vtec and all the other vtec wiring but i just dont know how to do get all the main plugs like the water temp plug, etc. im staying with OBD0 not OBD1. i was wondering if anyone can provide me more info on what would be easy and what to do. please let me know soon because im trying to get this done by next week. thanks
Old 04-12-2005, 02:59 PM
Scott82 Scott82 is offline
Re: (HELP) wiring from d16a6 to d16z6 vtec
you'll have to change the injector plugs out, the coolant temp sensor plug and relocate to the new sensor. Your old map sensor is on the firewall, the new one is on the throttle body, you'll have to lengthen that, i am not sure on the dizzy cause i think since you are staying obd0 then i think you have to use a obdo dizzy but i am not 100%. Use a 1 wire o2 sensor if you staying obd0.
Old 04-12-2005, 03:05 PM
well the main thing i really need to know is if i can use the 88-91 civic engine harness on the 93 ex motor. some plugs fit but there are like 4 or 5 of them that i dont know where they go.
Old 04-12-2005, 03:07 PM
wait im sorry. i put d16a6 to d16z6. i made a mistake. i meant d15b1 to d16z6.
Old 04-12-2005, 06:52 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you need to add injector wiring and if you want it to look clean then dist wiring. everything should switch over except for the injectors and dist. the coolant temp switch is now on the tb, or you can transfer your stock coolant temp switch and just use that, thats what i did. all the other plugs should fit
Team Lonely Drivers
