| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
pocket logger??
my girlfriend has a palm piolet, so all i need is the cable and software for the 2gen right? or do you have to have a certain piolet? where is a good place to get this cable?
thanks |
sdklfj
injectoclean.com
88 e300, needs work. 95 gsx, stock, sticky icky tires. SOLD! |
Re: pocket logger??
You don't want a generic scan tool like the one from that website. Pocketlogger is the most common software/cable I believe. Check their website for compatibility with your palm. pocketlogger.com
Re: pocket logger??
k thanks
Re: pocket logger??
ok another question, how does this logger work, where does it get its information from? if it gets the fuel trims from the stock narrow band 02 sensor then it would be point less to tune with this. you could tune with a volt meter on your o2. am i right?
Re: pocket logger??
The pocketlogger receives it's infomation directly from the ECU via the OBD-II port. The fuel trims are calculated by the ECU during normal cruising mostly from feedback from the O2 sensor. What we are concerned about is what happens at WOT. At WOT the ECU could car less what the O2 voltage is and looks at airflow. This airflow number is what the ECU uses to calculate fuel delivery.
With a 2g you tune for maximum timing advance, which is calculated by the ECU via airflow and knock. On a 1g you tune excluisively for knock.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
eriojgf
wha? was I looking at the wrong website? injectoclean sells obd2 connectors for pc, palm pilots and they sell generic scan tools as well.
Re: pocket logger??
If you just buy a cable, you can download free dataloggers such as OBD gauge and palm n stein.
http://students.db.erau.edu/~szabafab/stein/ http://www.qcontinuum.org/obdgauge/ Both are completly free, and work excellent for basic tuning. If you are tuning for more advanced things, DSMlink is the way to go. Almost all the palm's will work with most datalogging software, they actually have more problems with the newer palms. The stock narrowband will work but will not be any good for more than barely adequit tuning. If you really want to tune properly, you will want a good wideband o2, and preferably a dyno.
Need a GOOD 6-bolt engine? Quote:
'95 Talon Tsi EVO III GT, supporting mods, not running Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped. |
Re: pocket logger??
i figured the car not exploding was worth $175. Who can help you with proprietary softwares if you need help?
