Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-12-2005, 01:04 PM
charger912 charger912 is offline
Unhappy piston problem
I am installing new pistons and rods into my B16A2 and I think I'm about to have a big problem. From what I've read, the piston pins are either pressed onto the rods or are secured in the pistons and rods by other means. My problem is that when I put in the pins, they just fit right into the pistons and rods, meaning they slide back and forth pretty easily. There is nothing to stop the pins from moving back and forth. I'm afraid the pins are going to tear up my cylinder walls if I don't do anything. (The pistons are Nippon Type R and the rods are Eagle H-Beams, if that makes any difference.) Does anybody have any advice about what I should do?
Maybe I just be really stupid... I dunno...
Old 04-12-2005, 01:32 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: piston problem
have you installed the clips that hold the pin?
Old 04-12-2005, 02:04 PM
There were no clips. That's what concerns me. I'll check again but I don't even remember see a place for the clips to seat in the pistons .
Old 04-12-2005, 03:39 PM
Kind of a Big Deal
Re: piston problem
they may not have come with the pistons, you may need to order new ones.
Old 04-12-2005, 06:32 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: piston problem
full floating wrists pins. moves easy back and forth and are held in my clips on each side. so if it didnt come with the clips than call the company and have them send you some because there is suppose to be 2, one for each side
Team Lonely Drivers
