Old 04-12-2005, 12:50 PM
Lurchio's Avatar
Lurchio Lurchio is offline
First completed model - 911 Carrera
Ok, this is my first attempt at posting pics so hope they look ok, files are so small I can't believe they will come out ok but followed tutorial guide so I will find out once posted!
This is the first kit I have finished siince starting the hobby again this Christmas. I have also finished two others but let's see if this works first!
911 carrera kit bought on ebay - A pillar badly bent when I opened the box but think I've got away with it. Straight out of the box build except for turbo style rear lights and clear indicators.
Painted with Halfords Rover Blue and Halfords clear (never again - so thick!!!), Interior is a home made mix - very light deck tan I believe.
Anyway - if it works would love some comments - if not I'll no doubt be trying again soon!
Old 04-12-2005, 01:12 PM
mike united's Avatar
mike united mike united is offline
Nice paint, good work.
Mike
Old 04-12-2005, 01:16 PM
mickbench's Avatar
mickbench mickbench is offline
Looks good. Like the colour and it's got a good shine to it. I like it, and a great first build..
Well done.
Old 04-12-2005, 01:26 PM
Lurchio's Avatar
Re: First completed model - 911 Carrera
Well done.
Cheers Mick, I was hoping you'd drop in - you've been a good ear for my moaning these last few months!
Forgot to mention other nightmares I had with this kit. Firstly after final coat and hardening I wet sanded and rinsed the car. Then I shook it to get rid of excess water and managed to catch it on my jumper - tore the front bumper clean off and snapped up through rear arch to window - some extensive rework was required but you couldn't even tell now!
Not happy with the pictures though - shrunk them down so small the line definition has gone - any tips anyone - these are all under 80K but started off as 1.3Mb
Old 04-12-2005, 02:04 PM
Jurva's Avatar
Jurva Jurva is offline
Not bad. As far I can see, good paintjob.
Completed:
Top Secret Supra
Old 04-12-2005, 03:13 PM
blubaja's Avatar
blubaja blubaja is offline
Hey,
That looks really great for your 1st model. So clean! Keep up the awsome work.
Frank X.
Old 04-13-2005, 06:11 AM
Lurchio's Avatar
Any tips for better quality pictures guys?
Old 04-13-2005, 07:06 AM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Looks good to me, and just for info I use Halfords paint all the time, the trick is to lay down a few thin layers over the right colour primer. Dont try and apply to much paint at one time. With regard to pics I tend to compress them to 70k and use a size of 700 x 500 ish pixels.,is your camera set to highest quality?
Old 04-13-2005, 07:17 AM
Lurchio's Avatar
I was taking the pics at 3 Megapixel quality (can go up to 5) these come out about 1.3Mb. Then I just reduce the size on photo editor until they are under 80K
The quality doesn't seem to be half as good as most peoples posts on here though!
Old 04-13-2005, 08:02 AM
mickbench's Avatar
TBH they look fine, but I have problems taking pictures. I have now reduced the quality and size of the picture taken with the camera and this helps reduce them in disk space size, then resize to 800 x 600 to around 70 - 80kb.
Look OK, but nothing special.
Also looks like even though you broke the rear of the car, you can't tell at all.. Good body work. and I use halfords primer and works fine, but never used halfords paint yet. But I intend to try it one day.
Old 04-13-2005, 11:09 AM
Mogster Mogster is offline
I just love 911's, and you've done a good job on this one. I've already built the GT3 version of this kit and have another and the Carrera yet to do.
As for Halfords clear (I guess you mean acrylic lacquer), I've used this many times and I thought it was quite thin! - maybe you've not shaken the can enough? I've found that for best results you should do one, or maybe two, really light coats and then a much heavier coat, each about 15-20 minutes apart. Then leave well alone somewhere warm for a few hours. I much prefer Halfords auto paints to Tamiya or Humbrol, etc.
I'm no photography expert, but I usually take pictures for internet use at the lowest resolution setting the camera has, then crop away everything not needed, ie background. Then only if necessary, change the image size (number of pixels). This usually works out fine for me, with a file size well inside the AF 80k limit.
Chris.
West Berks Scale Model Club
Old 04-14-2005, 12:51 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I have found that there are two ways to reduce the file size on picture files. One is reducing the picture size. The other is reducing the pixel density. This does reduce the resolution, but if only viewing on a monitor, the resolution doesnt have to be great. This can be done with most picture viewing software packages.
