Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-12-2005, 10:15 AM
dirtydodge dirtydodge is offline
dodge fuel tank
I have a 96 dodge ram 1500 4x4 when I fill the tank I can only go
about 175 miles before the gage is on E and the gas light comes on.
so I go to the gas station and the tank will only hold about 10 galons
of gas. please help Im going nuts .
Old 04-12-2005, 10:23 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: dodge fuel tank
your truck should have a 23 gallon fuel tank you can check in your owners manule to make sure. sounds to me like your sending unit in the tank as either been replaced with the wrong one or just is not working right.
Old 04-12-2005, 10:26 AM
Re: dodge fuel tank
when the gas light comes on the truck runs relly
ruff like its out of gas , but it has a 23 gallon tank
thanks
Old 04-12-2005, 02:11 PM
Austin8214's Avatar
Re: Re: dodge fuel tank
I wounder if maybe you have had a baffel break loose in your tank then.
Old 04-12-2005, 02:18 PM
Re: dodge fuel tank
do you know if there is a drain plug on the dodge trucks, or do you have to drop the tank full?
thanks for your input
Old 04-13-2005, 10:38 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: dodge fuel tank
to drain you could pull off line at filter and turn on key and pump will pump into a gas can.
Old 04-14-2005, 05:56 AM
1thunder 1thunder is offline
Re: dodge fuel tank
by simply turning key on will not power pump for more than 2-3 seconds you must jump fuel pump relay to continuasily power pump
Old 04-14-2005, 09:54 AM
Re: dodge fuel tank
thanks I found a old fuel pump that works
so I jumped it from the batery and shuved the hose
down in the tank, sucked it dry.
thanks for all the helpm guys..
