Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-12-2005, 09:23 AM
Timber492 Timber492 is offline
Question No Spark From Coil
We have a '90 stang and can't get spark from the coil at all! We had put a new coil in but still no spark! Could it be the ECM or something else? I had checked the wires all the way back to the firewall to where it goes into the car, and it's all good there, but I didn't test the ECM yet. I did notice that there was a burnt ground wire below the ECM that gets attached to the floor on the passengers side. Any ideas? Thanks everyone!
Old 02-12-2008, 08:15 PM
yodler yodler is offline
Re: No Spark From Coil
Did you fix the problem? It sounds like the same thing I'm going through.
Old 02-13-2008, 12:42 AM
351wStang's Avatar
351wStang 351wStang is offline
Olddddd thread...
1969 Cougar
357w & TKO - 475hp
Old 02-13-2008, 09:27 PM
82Stang 82Stang is offline
If I'm getting no spark from the coil, I'd think that maybe a wire was bad or a bad ignition pickup/control module. I'd suspect that more than the ECM.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 02-14-2008, 09:50 AM
351wStang's Avatar
He re-opened a 3 year old thread to ask a question that he as already asked in another thread.
1969 Cougar
357w & TKO - 475hp
Old 02-16-2008, 02:01 AM
Pimpdady753 Pimpdady753 is offline
i had that problem to, i changed the little gray box on the distrubuter and now it works.
Old 03-24-2009, 09:12 PM
88stangGT 88stangGT is offline
try checkin the EEC solenoid located neer ecm lh lower kick panel
