Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 04-12-2005, 09:19 AM
rico46 rico46 is offline
Unhappy 01' Passat Won't start
I have a 2001 Passat with at 1.8. THis morning when I try to go and start it the alarm started going off and nothing else happened... I got the alarm stopped and tryed again... still nothing... after several tries I had to finally give up and ride with my wife to work... any ideas?????
Old 02-08-2006, 10:29 PM
myvwproblem myvwproblem is offline
Re: 01' Passat Won't start
Hi, 1999 Passat Wagon. Do you think is battery related? Appears to be same as my problem. The car is OK for a while but apparently battery is drained overnigth. I change battery twice, Nothing!. Local mechanic said is the radio/alarm system. I would appreciate your input.
Thanks
myvwproblem
Old 02-09-2006, 01:21 PM
6speed8 6speed8 is offline
Did you try your other key ? Veedubmechanic will correct me but I thing 2001 was the first year with the immobilizer. Could be anything from a weak battery to a bad key,instrument cluster,convenience module... Try another key and/or a jump start.
Old 02-12-2006, 09:43 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
dont you love vw alarm systems... i do!
if the immobilizer light on the cluster flashes when you try and start the car its something to do with the cluster, key, ecm, or ignition switch.
if the alarm just goes off its either a door latch, comfort module, or cluster
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
