Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 04-12-2005, 08:35 AM
strat6 strat6 is offline
front end noise
My 2001 stratus es is makeing a load squeal on the driver side only when I am above 30 mph. And not all of the time!It my do it for a couple of days then it goes away for a few weeks. It is not the brakes just changed them. Any ideas?
Old 04-14-2005, 01:28 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: front end noise
you may have a wheel bearing that's starting to go bad.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-28-2005, 08:58 AM
AdamOhio AdamOhio is offline
Im guessing your car has approx. 70-09k on it? if so, he's right. Most likely your wheel bearing hub assembly is gone. If your going to replace it yourself, replace both sides ..not just the one side. They cost approx. 75-100 ea. You will need "reverse-tork"(sp?) sockets to get the 3 retaining bolts out to remove the hubs. Forget what size..check with dealer. The center hub nut, if memory serves correctly, is a 1-1/2" nut..set to 100-105 ft/lbs.
Old 04-28-2005, 10:55 AM
xxxjayluvxxx xxxjayluvxxx is offline
Send a message via AIM to xxxjayluvxxx
Most Def Your Wheel Bearing
Shit happened to mine
Old 04-28-2005, 07:35 PM
Re: front end noise
No I only have 24k on it. I thought it might have somthing to do with the speedometer since it happens right at 30 mph and above and not all of the time. wouldn't the wheel bearing just do iy all of the time??
Old 04-29-2005, 12:27 AM
Re: front end noise
as the speed increases, the sound will get louder. You definetly have a bad wheel bearing, it's nothing wrong w/ your speedometer; if that was the case one of a few things would happen: your transmission would go into "limp mode," it will stick in second gear only, or your speedometer will not work. I'd follow the suggestion of everyone else, replace both wheel bearings while you're at it.
Old 05-02-2005, 11:12 AM
24K does seem quite pre-mature for Wheel bearings, however, on of two things could cause them to go bad real quick.. The factory either undertorked or overtorked your hub assembly when they installed it. When you first hear the noise, try turning your wheel hard to the left and hard back to the right. Does the sound get louder when you do this? If so, it could be they werent torked correctly, but unfortunately the hubs are now toast and need to be replaced. The ball bearings in the hubs are fried. Please heed to ft/lbs tork requirements on replacement..hubs will last longer
Old 06-17-2007, 12:39 AM
ac75001 ac75001 is offline
Re: front end noise
Just FYI and with respect -- it's TORQUE -- just thought I'd contribute hope no one is offended. Peace - A.C.
