Old 04-12-2005, 08:25 AM
Bakerytech Bakerytech is offline
94 Starting Problem
94 S-10 Blazer, Starting to have a problem starting, must push the gas pedal to floor to start.
Changed all plugs, wires, cap and rotor. Problem still there.
4.3 engine.
Any Ideals?
Old 04-12-2005, 09:43 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 94 Starting Problem
4.3 engine.
Any Ideals?
CPI or TBI?
Old 04-12-2005, 10:41 AM
Re: Re: 94 Starting Problem
Originally Posted by rlith
CPI or TBI?
CPI System
Old 04-12-2005, 11:29 AM
rlith's Avatar
Probably leaking CPI unit... Pull your upper plenum and look for washing.
Old 04-12-2005, 12:33 PM
Had the CPI replaced twice about a year ago. The frist one installed went bad within two weeks.
Usually you smell fuel when leaking correct?
Old 04-12-2005, 03:20 PM
rlith's Avatar
Not necessarily... Pull the plenum and check for washing. Did you have the nut kit replaced? But I forgot to say, before pulling the plenum, run a pressure tester at the shrader valve...Your fuel pump could be going out..
Old 04-12-2005, 06:29 PM
Had the fuel pump etc. replace about a month ago. Just checked pressure at start up 65 psi than drops off to 52 - 55 psi. running..
