Old 04-12-2005, 07:50 AM
jersejack jersejack is offline
rear defrroster
i have a 200 alero gl2 rear defroster doesnt work sheckd fuse its fine hhhhhhhhhheeeeeeeeeeeeellllllllllllllllllppppppppp ppppppppp
Old 04-12-2005, 08:05 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: rear defrroster
Checkout the rear defog relay to see if it is energizing. It should be mini relay #9 on the engine compartment fuse block. Have someone press the rear defog button and then listen or feel for a click. Good luck!
'02 Olds Alero GL2
Old 04-15-2005, 07:23 PM
jamcllw jamcllw is offline
Re: rear defrroster
This is pretty common on the n-bodies. You probably melted the box behind the c pillar that sends power to the defroster.
