Go Back   Automotive Forums Car Chat > Subaru > Legacy / Liberty / Baja
Old 04-12-2005, 07:30 AM
Capuano Capuano is offline
Question Wheel Offset for my '97 GT
I already know it's a 16x6.5 with 5/100 bolt pattern and a 73mm center hole, but what is the offset? My SVX has a +55mm, and I'm not sure if the Legacy GT is the same or if it's less than that. I'm wanting to put some aftermaket 17x7's on it with 225R17 40's, but I'm not sure they'll fit the inside clearance. If I can get wheels with a 10mm lower offset they should be fine, but NO ONE - not even the Subaru Dealer - can tell me what the original factory wheel offset is. They are the 18-spoke GT wheels. Anybody out there know for sure?
Thanks,
Mark
Old 04-12-2005, 08:30 AM
freakray freakray is offline
AF Modelrater
Re: Wheel Offset for my '97 GT
Here's a clue, the wheel offset is on the back of the wheel
Take a wheel off the car and look on the back side of the mating face, the wheel offset on Subaru's factory wheels is usually marked in this area.
AF User Guidelines
Old 04-17-2005, 08:45 PM
sha_zapple's Avatar
sha_zapple sha_zapple is offline
yup, its printed on the inside of the rim.
It should be 55mm. Depending on how wide you go, you can put anythign from 43-55 on a subaru safely. Heres the info I got off of www.nasioc.com
rim width.... offset
6.5" ....... +53 to +55
7.0" ....... +50 to +53
7.5" ....... +47 to +50
8.0" ....... +43 to +47
Subaru Legacy International
