Old 04-12-2005, 04:51 AM
seadweller seadweller is offline
Send a message via ICQ to seadweller Send a message via MSN to seadweller
Unhappy power windows
problem with passenger power window switch and window go up and down but the switch for the passenger side that is located on driver side doesnt seem to work checked the switch and its okay what could be the problem?
Old 04-15-2005, 11:46 PM
jimmypodunk jimmypodunk is offline
Unhappy Re: power windows
Wires to the switch could be shorted. Without a schematic I couldn't tell you if there are relays in the system.
Old 05-28-2005, 12:50 AM
carmac carmac is offline
hope its not too little, too late. I had the same problem. I had to replace the drivers double gang switch becasue the little cover broke off. after I replaced it, i noticed that the passengers switch now works flawlessly.
Old 06-02-2005, 06:04 PM
bovic
Guest
Posts: n/a
Re: power windows
I have a similar problem, my passenger window won't work from the passenger sid and this morn it went down just a bit from the driver's side but that's where its at right now.. Won't go up again, only the passenger window is in trouble.. Weird.. I'm to check that tonight after work..
Old 07-19-2005, 11:37 PM
shroom shroom is offline
Send a message via Yahoo to shroom
Re: power windows
same here carmac, i put my drivers side switch in the other astro and it worked, and i tested the passenger side switch in another astro and it worked, well come to find out i pulled the window motor out and its shot, it went up and down 3 inches and that was it, so had to replace the window motor, getting it out......gotta drill out the rivitets
